Does anyone know if the 17in. wheels from the '02 A4 Sport Pkg. will fit
an '02 A6 4.2? Are spacers needed/recommended? As always, thanks for your advice/opinions.
Patrick
Patrick
I have them on my 2.7T but I would think on the 4.2 you would want something a little wider so you could run the larger 255 or 265 tires.
You can see them on my 2.7T if you look at my picture poster.
A4s have a 45mm offset vs 35mm for A6 4.2.
Greater offset means the wheels sit further IN, not OUT. The smaller offset the more wheels stick out. The reason for 10mm spacers is to make a 45mm offset wheel to be like a 35mm one.
Wheels will not fit without spacers no questions about it.
centerline and the wheel mounting surface. If the wheel is narrower, you need different offsets! In this case you need the wheel width.
I have 16" 2.7T wheels that fit on my S6 (for winter). Yes the offset is more but is a 16X7 wheel as opposed to the 17X8.
the 02 A4 sport package has a 7.5" width wheel. I don't know the offset. If it is 45mm (as posted earlier. You have 1 cm more offset from the center. but the wheel is 1.25 cm narrower. So in effect the real difference is 1.25/2=.625 cm (the extra width on one side of the wheel) - the offset difference. So your tire will be .375cm closer to the strut. Maybe it will fit<ul><li><a href="http://toy4two.home.mindspring.com/offset.html">offset calculator</a></li></ul>
the shape of A4 wheel, as seen from inside around mounting area, will not clear huge 4.2 calipers, hence the reason for spacers to provide needed clearence. Smaller spacers, 5mm or 8mm, could work, but I do not see weels fit without any at all.
