Drain Plenum Chamber Water - How?
the easiest way is to flip whole car upside down
The other way is to open the hood, remove the black cover and clean the holes in the bottom of the chamber. Basically there should not be leaves or other junk blocking these holes and as a result there should not be any watter.
I think you mean "drain holes" beep. Here is the referenced plenum I think
Black rubber plug on lower right of picture (that would be the driver side) is for draining I beleive. Remeber this plenum comes from a 1997 beater A6.
<img src="http://pictureposter.audiworld.com/12414/intakeplenum.jpg">
stevenmurray
02-04-2008 07:21 PM
