Eibach pro-kit spring install. Rear didn't get any lower?
#11
not the springs, the perches.... but i have nto had that particular model apart. Many can go in "wrong" and still go together. That tales them from convex to concave - and about 1" difference. Ergo my comment
G
G
#13
I took everything apart again and discovered that everything was installed correctly the first time. I have no explaination for the discrepancy in height. Additionally I discovered the right side is about a half inch higher than the left. Against my better judgement I broke out the cutoff wheel and removed half a coil from both springs. The left side now seems good and the right side still a little too high. Pictures to follow.
#14
Ever get some pics together? I'm interested in having a slight rake by using eibach pro feathers just on the front. Eliminate some front wheel well gap and improve handling maybe. Also, did you bother with adjustable uppers?
#15
Thanks for all the replies. I definitely will let it settle in a little before doing any cutting. This is the first time I've installed the Eibachs on a quattro car. Definitely more challenging in the rear, but I was curious about what I could have done that would have been incorrect on the install that would have kept the rear end raised up a little. Is there some detail I am unaware of? Thanks
![](http://i32.photobucket.com/albums/d31/q2quest/IMG00012-20100211-1049.jpg)
![](http://i32.photobucket.com/albums/d31/q2quest/IMG00013-20100211-1050.jpg)
AndrewsQuattros
10
03-15-2005 09:39 AM
ex-a8drifter
19
02-28-2005 08:24 PM
sowacycling
06-07-2004 11:35 AM
ATMOS
03-09-2003 08:57 PM
siberian
04-29-2001 08:30 PM
