Engine is missing bad..here are the fault codes
So thanks to the list I was able to locate someone locally with Vag-Com. Thanks much Alan!
My car started missing real bad yesterday and flashing the CEL. I got the following trouble codes, any idea where to start? It is a '99 A6 Avant-2.8 30V:
VAG-COM Version: Release 607.3-UD
Monday,05,March,2007,05:32:58
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
Address 01: Engine
Part No: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D03
Coding: 06252
Shop #: WSC 02325
6 Faults Found:
17930 - Camshaft Adjustment; Bank 2: Malfunction
P1522 - 35-00 - -
17927 - Camshaft Adjustment; Bank 1: Malfunction
P1519 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16686 - Cylinder 2: Misfire Detected
P0302 - 35-00 - -
P0300 - 35-10 - - - Intermittent
P0302 - 35-10 - - - Intermittent
Readiness: 0000 1101
The camshalf adjustment faults have me worried. the car has 89,200 miles, I had the timing belt service done early- at about 70k, when the cam tensioner seals were leaking, and have not had any problems since. Any one have an idea of where I should start?
Thanks, Paul
76 77
Address 01: Engine
Coding: 06252
Shop #: WSC 02325
6 Faults Found:
P1522 - 35-00 - -
P1519 - 35-00 - -
P0300 - 35-00 - -
P0302 - 35-00 - -
Thanks, Paul
Before you do anything else check the timing belt and cam timing. Do not drive the car...
...until you are certain that the belt is OK and the cams are still in time. The fact that both banks are complaining about cam adjustment could mean a problem with the belt. Cam adjustment issues will result in misfires too.
Re: Before you do anything else check the timing belt and cam timing. Do not drive the car...
Yesterday I replaced a bunch of the vacuum lines (the little ones by the intake 5mm?) that were suspect hoping it would be the problem.
After I replaced the hoses I drove up and down the hill by my house with out any problems or miss fires, the CEL was still on though. I then drove it today about 6 miles to get the Vag-Com completed and results and it was missing so bad on the way home I barely made it.
But since it drove with out miss firing last night could that eliminate the cam timing and belt being off?
You could be right. It could also be related to a crank sensor failing......
alos there is a possibility it is just a very low battery not able to maintain enough power to keep eveything at the right voltage.
