Engine wont start first try when cooled off...
I have a 2001 A6 2.7T Tip Quattro. In the morning or anytime after the car has been sitting off for over an hour it wont start on the first try. It cranks and cranks but wont start, sometimes it kinda will, it will be at an extremely low rpm and seem to die off unless I give it gas, but it seems bad so I just crank first for 2 seconds then turn it off, then it will start right up on the second try like normal.
I just changed the spark plugs and oil, but that didn't help.
The only issue with the car is that my secondary air pump seized and I took it out and am going to rebuild, but I know that is not the problem.
Any ideas?
Any ideas?
check fuel pressure with a gauge. Leaking injector(s) or check valve will drop fuel pressure and fuel won't happen.
not saying your wrong, but wouldn't there be fault codes for engine running lean or insufficient fuel flow? i just dont have gauges and have no idea how to check fuel pressure, but i also feel that there would be a code for that.
Depends on how the software was written. Things like a leaking injector or insufficient fuel pressure for instant startup might not set a code since the engine isn't on when these things happen. Codes are generally set when engine is running, not necessarily starting, especially if the engine starts and pressures come up.
Here's the real deal...not everything can be done by reading a code...sometimes you have to go old school and get your information the hard way. Fuel pressure øn a fuel injected engine happens to be one of the primary bits of information. It would be nice if vag-com could log fuel pressure over a few minutes of time, say from the time you turn on the ignition (not twist start) through the key twist to start and then to a few seconds after the engine starts.
That's somewhat different from just looking for a code.
Any ideas?
Any ideas?
ajajaj, sooo complicated, why cant it just be a simple $10 sensor, lol.
i'm gonna read that vag logging thing now and see if I could determine if there is low fuel pressure before the first try. then see what happens to it after I turn off the engine on the second try. i'll post results soon.
