Engine wont start first try when cooled off...
#11
ajajaj, i guess our cars dont have a fuel rail pressure sensor. looked from 100-109 and not there. =( I guess i'll take it to a shop, and hopefully its a simple hose job.
#12
car died
so I was living with the issue of it not starting on the first try since I posted it here.
and last night after a 2 hour drive the car is dead, wont start at all, just cranks and cranks, almost starts to hesitate but doesn't catch on. what the hell can it be? I just took the fuel pump out and tested it, its working fine.
#13
It's more likely bad if you've replaced it than if you haven't. Always look at the last thing you touched. My money was on vacuum leaks, but now, not so much.
#14
got it started again, but i cant live with this
car is pretty much useless now since I cant go somewhere and park without worrying if it will start again and then i'll have to pay for a tow truck.
anyways, i did order a coolant temp sensor, so I'll change that when it gets here, I have my doubts about that being the problem but who knows with these cars.
<b>Any ideas are welcome,</b> i'm even considering asking my local shop if they can check the fuel pressure. That way I can eliminate leaking fuel lines...
I really need this fixed, I cant live like this. This is like the most mysterious problem ever. My engine runs like its new but I have to worry if it will start or not. GRRRR
#15
dead again
wont start again, cranks cranks, no go.
I took the accordian hose off, sprayed 2 seconds of starter fluid, I can get the car to run for 2 seconds before it dies. So it seems I have spark but no fuel...
Oh, and to keep it running on the starter fluid I have to tap on the gas pedal, and sometimes there is this tractor gear sound from the middle of the engine when i rev it up ....
Any ideas? Please
Any ideas? Please
#16
i tried to jump the fuel pump relay, but i dunno if i had good contact with regular 110v power cord. I jumped 30 to 87A and 87 still didn't start... Do I need better jumper cables or it should have worked if it was indeed the fuel pump relay thats bad...?
#17
i took the cover off the fuel pump, and put a meter on the connecter, it stays at 0 when i put the key to on, but when i turn to start the voltage goes up...
I connected the connecter and put my hand on the cover to the fuel pump, and tried to start the car, I didn't really hear anything or feel anything...
i'm going to take the fuel pump out again and test it once again. ughhh soo annoying. =(
#18
F$*(
It was actually my fuel pump. Since the problem was intermittant, it explains why it worked the first time I took it out. This time its dead. Ughhh these cars are sooo annoying. Heh. But I still love my car, minus the fuel pump, lol.
So who has a brand new oem one laying around? I'll take one for $100 =D
badinstincts at yahoo.com
#19
well, so i wanted to see if I can clean the fuel pump a little and get it to run while i wait for the replacement to come. I tapped it a little to free it up, it started running again so I cleaned it up a little, vacuum cleaner and some electrical cleaning spray. Put it back in and got the car started, took a couple of tries with a lot of hesitation... So I let the car run for a minute and shut it off to see if it was reliable for the moment.
Nope, wont start again, ughhh. I guess I cant use my car until I get the new one, unless I want to take the fuel pump out every time to free it up... Ajajaj
#20
How did it end?
Sooo, what did you finally decide was the problem to the car not starting when semi-cold. I'm having the same problem with a 2013 TT
