ESP module location?
This was under the back seat on my B5 S4. Not sure where it is in the C5. I am not talking about the ABS module under the hood.
I need to trace the wires from they yaw sensor to the brain. Still getting an intermittent yaw sensor code when we go over bumps.
thank
thank
"The electronic stabilization program hydraulic pump for traction control -V156- and the sender 1 for brake booster -G201- are on the left side of the engine compartment beneath the ABS hydraulic unit -N55-."
ABS/ESP assembly page doesn't mention a separate controller for ESP. Controlled by the ABS module?
Scott Massey,
Did you ever fix this issue - I have the same error code and intermittent but frequent ESP light activation plus ABS activation on an 02 Avant.
I'd be interested to know what came of your car's problems.
Thanks.
Thanks.
My2ndS4
08-11-2005 09:50 PM
