Ever wonder why the bi-xenon low beams are dimmer than regular xenon?
Here's a comparison between three types of A6 projectors: halogen, bi-xenon & regular xenon. The bi-xenon have the additional benefit that they allow more light out when the high-beams are powered up, but their low-beam pattern is more restricted - see below.
Halogen Low-beam Pattern:
<img src="http://pictureposter.audiworld.com/55916/1_halogen_pattern.jpg">
Bi-xenon Low-beam Pattern (Much better):
<img src="http://pictureposter.audiworld.com/55916/2_bi-xenon_pattern.jpg">
Regular Xenon Low-Beam Pattern (Wow!?!?!):
<img src="http://pictureposter.audiworld.com/55916/1_xenon_pattern.jpg">
Bi-xenon High-beam Pattern (Nice!) Note: The high-beam halogen bulb is NOT wired-up in this test:
<img src="http://pictureposter.audiworld.com/55916/2_bi-xenon_hi-beam_pattern.jpg">
To obtain the same low-beam pattern on the bi-xenon setup, remove the large shield masking the inside top of the projector: <a href="https://forums.audiworld.com/a6/msgs/509100.phtml">Step-by-step Instructions</a>
<img src="http://pictureposter.audiworld.com/55916/g4_remove_shield.jpg">
Shields - Bi-xenon vs H7 Projector Shields:
<img src="http://pictureposter.audiworld.com/55916/g5_shields_top_bi-xenon_bottom_h7.jpg">
Bi-xenon Low-beam Pattern with H7 Shield:
<img src="http://pictureposter.audiworld.com/55916/2_bi-xenon_pattern_wo_shield.jpg">
Alternatively - remove the shield altogether, the pattern is slightly more rounded at bottom - not much difference.
My first attempt was with the relays - no go. It appears the lower DRL voltage is fed into the switch, then the fuses, and finally the light controller.
I've read various post here and on vwvortex about pulling the switch and bending the pin.
I cannot pull the switch out. I removed the knee panel, and the switch cover. I can push on one finger to loosen the bottom. The top is hard to get to, but I may be able to insert a flexible blade to push it down...
