Excessive road noise = Tires or Wheel Bearings, right? Getting out of hand...
Old 11-21-2007, 07:37 PM
Buff-Daddy's Avatar
Default Excessive road noise = Tires or Wheel Bearings, right? Getting out of hand...
I have Dunlop SP9000's which have a history of growing louder with wear, but I cannot imagine this amount of noise can be from the tires alone. It is consistant and only improves a little on different surfaces. Hard to hear on my cell phone which is a problem seeing as though I am in sales and live in my car. Putting on winters soon which might not be any better, so not sure that will help define the problem. Any other ideas/suggestioons?
Old 11-21-2007, 07:50 PM
New Member
Canadia's Avatar
Default It's very difficult to distinguish between the two noises...
Comparing the noise caused by a bad wheel bearing a couple months ago with my exceedingly loud set of Avon's, it's nearly identical.
Couple points of differentiation: the wheel bearing will sound the same no matter the surface; with the tire you'll notice marked change in the vibration noise over different surfaces (e.g. freshly paved road). I think the winters will be a big help in troubleshooting. If the noise hardly changes, its probably a wheel bearing. In any case, it couldnt hurt to have it looked at by a mechanic - you've got to expect these things eventually.
Old 11-21-2007, 07:51 PM
Buff-Daddy's Avatar
Is it odd at only 45,000 miles?
Old 11-21-2007, 07:54 PM
jlag's Avatar
Does the noise increase/decrease when you corner hard left or right?
Old 11-21-2007, 07:55 PM
Buff-Daddy's Avatar
What kind of $$$ am I looking at if it turns out to be a bad wheel bearing?
Old 11-21-2007, 07:57 PM
jlag's Avatar
Wheel bearing "noise" will be a much sharper feel than tire "noise" as the side wall is not absorbin
Old 11-21-2007, 07:59 PM
jlag's Avatar
It is more of a "feel" than a "listen" for the difference.
Old 11-21-2007, 08:01 PM
jlag's Avatar
Add 2 hours to a break job each side, if mechanic has "Hub Shark"
Old 11-21-2007, 08:14 PM
jlag's Avatar
It is odd at 45K, usually 90/110K for the first out of the four for me.
Old 11-21-2007, 08:16 PM
New Member
Canadia's Avatar
Mine went around 80k
Quick Reply: Excessive road noise = Tires or Wheel Bearings, right? Getting out of hand...
