Fitment of HP2 calipers on A6 2.8 Quattro...
I've managed to source a pair of new HP2 callipers with associated disks, pads and will be retrofitting these onto my A6 2.8 Quattro Avant (yr 99). My question is, will they fit beneath the standard 7 x 16" ET45 5 spoke alloy wheels?
There are also at least two HP variants--the 4.2 and some 2.7T with the deeper offset to the rotors, and most 2.7T's and S4's with the smaller (16.7mm) offset. 4.2's also have the aluminum suspension bits throughout and the lightweight wheel bearing assemblies; those were a running change I think only in later style updated non-4.2's. Not sure how the outer CV joint and ABS sensor pick up in turn relate to that.
Net, you could end up changing all kinds of stuff as you try to sort through this.
I obtained these new callipers, disks and pads for free(long story!) and believed if neively that they would be a straight replacement - I'm I wrong then.
the brakes are not plug 'n play. Search the B5 A4 forum, and a lot of those guys put hand-me-down B5 S4 brakes on.
Your car came with the wineglass wheels, though, right? The 5 spokes were standard on the 2.7T non-sport, so they will fit. I *think* there was an A4 version, as well, that probably will not fit.
lcmm55
A6 (C7 Platform) Discussion
03-05-2016 06:21 PM
Aralan
A4 (B7 Platform) Discussion
11-04-2005 02:52 PM
dejavu
10-17-2002 08:11 AM
