Follow-up on '02 S6 Avant brake job
(rears only).
Did the job yesterday. Easy, except:
i could not get the rotors off. Or not without using force that I didn't want to.
Are the rotors secured in any way except by friction and lug bolts?
The seam between the rotors and the hub is so fien that we could not be sure whether it was a seam at all, and therefore whether the rotors just popped off (hah!) or was actually held by the axle nut.
Grant
Grant
There are no retainers for the rotors, they rust to the hub. My right rear rotor has hammer marks on the wheel mounting surface, placed there by the dealer when it was removed. A liberal coating of anti-sieze will go on the hub when I mount my cross drilled and slotted rear rotors.
check the back of the rotor, are there any other screws you missed? there shouldn't be any really. It's a floating rotor.
out of curiosity, parking brake is off right? you're able to seperate the caliper from the rotor? there are two hex bolts connecting the calipers to the axle, once you take those out, the calipers come out (assuming parking brake is off). I've been assuming that's all done and you just have a rotor that's stuck on the axle.
If you look at the front of the rotor, the seam between the rotor and the hub is so fine that it is basically invisible. So, even though I suspected everything "you all" have said, I didn't want to pry/hammer/heat it if in fact it was attached by the axle nut.
Apparently its just rusted/ pressed in place. Heat should expand it and allow it to be freed in that case.
Since the rotors were really in pretty good shape, I just put them on the shelf for next time and put it all back together.
By the way - for anyone else doing this job, I somehow managed to get one of the pads (inside, left) crooked. Bad, bad. Handbrake did not work, brakes did not apply, and pad dragged, making that rotor.caliper VERY hot within 2-3 miles. Taking it all apart, cleaning, lubricating and re-assembling fixed it.
Moral: make sue the caliper is really free-floating very freely before you "close her up". The apply the brakes very lightly the first 1-2 times to ensure they all seat properly.
Grant
Grant
excellrec
Audi 100 / A6 (C4 Platform)
02-02-2009 06:53 PM
vwgti16vt
01-22-2009 12:20 PM
SolidFish
06-14-2006 12:08 PM
coupe d'mike
02-03-2005 07:55 AM
skategoat25
10
07-14-2003 07:41 PM
