found these in my coolant reservoir
So I was going to replace my coolant temp sensor because I have having similar issues as discussed in this thread.. (https://www.audiworld.com/forums/sho....php?t=1693546)
when i opened the coolant reservoir, in hopes to relieve some of the pressure, i peeked in and saw these three items sitting in it! I used a wire hanger to fish em out but there is still one smaller spring in there. I do not normally work on my own car but i wanted to try to do this job and I am really surprised these were in there.
the problem i am having is that my 2000 a6 wont start after it has been running for over 5 minutes and is still warm. it has to cool down all the way to the under the first notch on the temp gauge in order to be able to start it again. i hoped that replacing the ECT that i would fix the problem but now I dont know what kind of other stuff might be in the coolant line!
anyone ever seen anything like this before?! any advice would be greatly appreciated for now i do not know what to do.. thanks in advance from a mechanical novice!
The cap seems like it is the correct one. I will take a photo when I get home. My question for you guys is what should I do now? I know there is at least one other small spring in the reservoir and no telling if something is stuck in the line somewhere. Any advice would be greatly appreciated.
The obvious answer is to get the parts out that you can. Worst case is disconnect the connector on the bottom of the expansion tank and remove the hose going to the tank and dump the parts out.
I wouldn't worry about any other parts that could get through the very small orifice.
I got out what I could, I think the only thing still in there is a small, half inch long, half centimeter diameter spring. I think that it could fit in any tubing that leads into the reservoir.
I agree that those definitely look like t-stat parts. They are, however, too large to travel by hose to get to the reservoir. Perhaps someone dropped them in?
