Front or center engine mount 2003 A6 3.0
where can I find the spongy looking thing that looks like a center engine mount on the A6 3.0 2003 car. Mine is shot. it's the software material that you can see when you put the car in service mode. not usre if it's a engine mount or not. just wondering what it will do if it's shot?? will teh engine shack a little bit?? it's not a problem I just want to replace it and I need to know what's it's call or where to get one.. Dealer has no clue.. looks like it's pushed on , on the engine side and when the front is put back in normal mode it pushes in under radiator.
http://www.thepartsbin.com/catalog/index.php?N=1574 9604 4294962954&Ntt=engine+mount&No=10&Npp=10
Boge Front Motor and Transmission Mount Stop - Direct OE Replacement
2002-2011 Audi A6 Quattro
Front Buffer
Fits: Front Buffer
Front Buffer
Fits: Front Buffer
I bought the following mount for my 3.0, supposedly a replica of the APR polyurethane snub mount.
http://www.ecstuning.com/Audi-C5_A6-...Mounts/ES4665/
Hmmm, that kind of looks like it, Did you have to put the car in service mode to install it?? this is the mount in teh front center and under the radiator. Has the spongy thing originally. The discription sound like what I need. I'm getting a funky shake when I drive the car almost feels like a tire out of balence but is not consistant. Not real bad though.. just trying to get rid of the vibration... I think mine is shot..
Mine was shot at 90,000 miles, cracking, splitting, and very spongy. Service position is needed to install the mount *correctly*. This involves tightening the mount on block side, but leave radiator side loose, start engine let idle a couple minutes, then center and tighten the radiator side mount.
New mount drastically reduced vibrations afterwards.
![](http://img805.imageshack.us/img805/6167/photoiq.jpg)
I just did the timing belt and had the in service mode. I think that's part of my problem, a very little shake. Makes the car feel loose when driving it. Thanks for your help, I'll have to go buy one. and put it in.
I have a a4 b6 with 3.0 v6. I loosened the mount on the motor and mount on bumper side but cannot pull them out of the car. What am I supposed to do to get the out , so I can install the buffer
d6lc
08-13-2013 05:26 AM
Houpty
Audi 100 / A6 (C4 Platform)
07-16-2007 10:16 AM
2002, 30, a6, audi, audiworld, center, engine, front, installation, instructions, motor, mount, mounts, replacement, stop
