front end vibrations/harsh ride
so for a while ive been having a lot of shimmying, clunking and vibrations at various speeeds. seems worst when i first start driving at low speeds, and at any speed above 75mph. ive also noticed that the ride quality seems unusually rough, like coilovers with no dampening adjustment rough.
if there are any suggestions to narrow down what it might be im all ears.
so far im thinking, engine (and transmission) mounts, front axles (outer cv joints, the one on the right clicks the left clunks lol). and maybe wheel balance.
im also thinking about a wheel bearing issues as i get a faint howling at freeway speeds from the front right. could i swap the front right with the front left to see if the sound moves with the bearing?
last but not least, will this shimmying, clunking and vibrations cause any further damage to other components or is it more of a ride quality issue only?
Did you check your control arms for play? Check bushings on the sway bar for wear (clunks)?
Raise the car and get it all checked.
Where to start?
First, yes, continuous vibrations (out of balance wheels, etc) accelerate wear on suspension components. Not overnight, but its wear, of course.
Now, where to start. Unfortunately you need to eliminate things one by one. Did this start suddenly? If so what happened in the interim?
I'd begin with balance. I'd also begin by spinning the front wheels and looking for any run-out - wheel or tire -- lateral or radial.
The harsh ride seems unrelated. Have you checked that your dampers are functioning properly?
Finally, Cvs should not make noise. Do you feel it throught he pedals/floorboards? Worse when turning?
you may have multiple problems. What has been replaced? How many miles?
I'd begin with wheels/tires. I'd check dampers next (bounce it at minimum). jack up and rock wheels at 10/4; 9/3 and feel for play (not the rack moving, actual play). Is a CV boot torn? They rarely go except when grease goes out and dirt in. Not impossible, but rare.
Say more.
G
Say more.
G
oh yea, i forgot about the WB.
It will begin as a drone and a roughness through the steering. As if things are not smooth. Mostly because they are not :-)
The drone will get worse, and will get louder if you turn the opposite direction from the offending bearing, loading it. It will liekly be silent unloaded (e.g.: on a lift).
G
G
the absolute last thing i can think about is when i was working on the cv joint/axle i was loosening something or moving something and i heard a loud pop from what i thought was the steering rack arm, but ive had no steering problems so that may be coincidental
G
G
Let me know how it goes I have similar issues...... When turning I get vibrations ...also I get vibrations in my feet and floor at all speeds ..but seems to come and go ( not consistent ) somedays seem worse ..
double check that the CV is good, that it is seated properly. I can even imaging an aftermarket part being slightly off dimension - they must be tight (no play) yet move very freely. Like, well, nevermind.
But tires/wheels are so notorious i nver ignore them. but you keep coming back to the CV, so it may be time to dis-assemble and investigate. Plus if there is grease, something broke again.....
God luck, off to a full day of coilover install
G
G
In feet and floor; come and go indicates a couple of possibilities:
1. small imbalance or loose bearing in driveshaft (propshaft)
2. possible REAR wheel vibration for any of the million possible reasons (balance, tire OOR, wheel OOR, ..)
G
G
OK, after reading the answers and replies, all I can say is this car is badly treated and poorly maintained. Whether money or time is an issue, first thing to do is fix all the obvious issues such as torn cv boots and/or the axles that may be ruined. Perhaps after that some reason may be attained. Otherwise it's just bench racing.
