FUSE displayed in Trip Odometer
Old 12-30-2012, 06:03 AM
  #11
jcman's Avatar
Default Ok, I'll word it this way
Originally Posted by allessence
Thanks. I believe it's a later 2000 up error.
My reference of this dEF error in ebahn is for all years of the C5 to the OP
Old 12-30-2012, 06:13 AM
  #12
jcman's Avatar
Default The FUSE error
Other Audi models have had this error including the A6, it means low power to the cluster.
I have read this was caused by a bad power feed anywhere from a bad alternator regulator, ground connection or power connection to the two fuses for the cluster or an open fuse
Old 12-30-2012, 06:50 AM
  #13
allessence's Avatar
Yes, you are correct.
It is no power going to the cluster for the Voltage/alt warning/gauges.
though the voltage is at the required 13.8-14.8Volts at the alt and wiring..
Again, there must be a short somewhere this is the info I am looking for.. The fuse doesn't blow right away.. It takes 10-15 seconds this tells me that there is a relay somewhere that has a bad power feed coming off of it.. Thus the blown fuse.
Was hoping someone would have dealt with this problem and knew of the quick fix vs tearing into it.
Old 12-30-2012, 07:01 AM
  #14
jcman's Avatar
Default Post confusion
Are you the OP?
Old 12-30-2012, 12:05 PM
  #15
allessence's Avatar
Op?
Old 12-30-2012, 12:19 PM
  #16
jcman's Avatar
Op?
The "Original Poster"
Old 12-30-2012, 12:36 PM
  #17
allessence's Avatar
Nope.. Just someone who stumbled upon the original post and having the same problem.
Old 05-21-2017, 11:19 AM
  #18
Jimreynolds503's Avatar
Default Fuse shows in instrument panel and 10amp fuse blows right away
I am having this issue. The 10 amp fuse blows instantly when replaced. Assuming a ground issue,but hoping for more info.....
Old 05-21-2017, 12:02 PM
  #19
georgeb944's Avatar
A zombie thread from five years ago.
Old 04-05-2022, 01:49 PM
  #20
Arokebra's Avatar
Was same problem and was Fuse 14 was blown which is one of the instrument cluster fuses. Seemed like a pretty drastic warning for such a simple issue but there it is. Replaced it and everything is back to normal
squishybot
07-06-2007 01:44 PM
Jetace1
08-07-2005 04:24 PM
Adam Mowafy
15
02-08-2005 07:12 PM
JoelA-K
Audi 100 / A6 (C4 Platform)
06-15-2003 12:11 PM
Peyton Place
Audi allroad
06-17-2001 06:03 PM
Quick Reply: FUSE displayed in Trip Odometer
