Fvck. I think I just figured out what was causing my CEL : ( (long)
#25
If they do anything to circumvent or disable emissions equipment they could get in big trouble. Your best bet is to first determine if you have loose material in the cats. If you do remove them and break out the core. This will probably cause a CEL, but it will prevent power loss and heat build up due to a clogged cat. This should only be a temp fix until you can replace the cats.
#26
willing to weld them back together after I've gutted them? That would be just like putting in a set of straight pipes for me..
jcxp15
06-03-2007 03:53 PM
BoneDaddy
05-04-2007 05:29 AM
