Gauge cluster swap problem
Well i bought a used cluster with working LCD and installation went fine but for some reason my electronic immobilizer turns on with the new cluster.
anyone know of ways around this?
thanks
thanks
generally no. After 2000 they had the immobilizer and it can be very difficult to reprogram. If you can live without the cluster for a couple weeks then you can send it out to get to repaired. I had mine done at module masters in Canada and now it works perfectly. Its even guaranteed for quite some time.
Give your local dealer a call however. There is always a small chance they can help. If it costs over $300 then you might as well fix the original one however.
Ron
Odometer, no.
This is a poor idea. Have the other cluster fixed and reinstall it.
I would try to get it repaired but i cant be without the cluster for that long. Ill try to call the dealer and see whats up with getting the info swapped over. thanks guys
what is your car year model ? Can you start your car with this new cluster ?
early models up to 2001 don't have immobolizer built in, Immbolizer is tight into key, ecu, and instrument cluster
Do you have your existing cluster, look at the sticker on your top right cluster you should see part# plus immbolizer number below it will start with AUZ.........
if all the dots are zero then your car don't have immobolizer
if all the dots are combination of digits and numbers then you have immbolizer number
now look at the cluster you bought, if you have the flashing car with key on your new cluster , and the top sticker have immbolizer number , and you can't start the car , then you have to program your new cluster into your car, then you need 4 digit SKC code from your orginal car cluster and your new cluster in order to program to your car, in order to get the 4 digit code you need to go to dealer and have them instaall or provide you 4 digit key for a fee, if you don't have access to tools like VAGCOM
if you can turn your car on and drive with this cluster that means that you don't have immbolizer in your car , however the new cluster the only way to stop the flashing of the immobolizer light is to cover it with black eletrcial tape, your can't turn the immobolizer off , it is program to that cluster, and nothing you can't do about it.
As others recommend , best way to avoid any headache is to fix your existing cluster, you don't have to worry about re-programming, your missing mileage and anything that is programmed into cluster will not be lost.
