Getting 90,000 service, need advice
Hey guys, I figure I ask the experts. I am going to get a recommended 90,000 mile service which requires the removal of the front end. Can someone please give me and complete list of things to change..from what I understand the list is as follows
Timing belt
timing belt tensioners
water pump
..I know that there are some other belts that should be changed so please help me out
Timing belt
water pump
Re: Getting 90,000 service, need advice
Timing belt
Tensioning roller
tensioner
tensioner pivot arm
tensioner
idler
water pump
thermostat
coolant flush
Cam adjuster seals (2)
valve cover gaskets (2)
Cam seals (4)
cam caps (2)
crank seal
Serp belt
Maybe serp belt tensioner if you aren't the DIY type
suction pump
green check valve
What did I miss?
Tensioning roller
tensioner
tensioner pivot arm
tensioner
idler
water pump
thermostat
coolant flush
Cam seals (4)
cam caps (2)
crank seal
Serp belt
suction pump
green check valve
What did I miss?
jdubs914
9
02-01-2012 09:09 PM
IB Adrian
21
11-25-2009 09:48 PM
99 quattro
03-04-2007 07:14 PM
BlackS4tt (Josh)
Florida Discussion
09-08-2005 05:27 PM
lskolnick
07-27-2003 08:15 AM
