Going for smog but have bad o2 sensors, via vaq-com.
Could I pass by only replacing the primary's or are the rears as important or more important? I was told to replace the rears first. what do you guys think??
So I will just say "no".
Year and engine?
Codes?
Which sensors are "bad"?
How do you know?
What kind of emissions testing do they do in your state?
Year and engine?
Codes?
How do you know?
2000 2.7t
vaq-com says all o2's are bad
california smog
could I pass with only primary's replaced?
california smog
so really there is little chance it will run properly if they have failed. The secondary sensors are only there to check the function of the cats.
If all four have failed, whihc is rare, it suggests there may be a different fault caus them to fail - ie, the may have no feed for the heater elements or there may be wiring damage etc..... but it rare for all four to fail, unless the car has been run on leaded fuel?
Why not fix the problem?
It is unlikely that all four sensors are dead. Look elsewhere.
You emissions answer depends on how CA does the test. If they scan the car, it won't pass. It might pass a tailpipe sniff. Just fix it.
When my o2 sensor (singular usage you'll note) went on my ancient 1991 90q20v, it ran ridiculously cleanly. We thought the machine was broken. But it also ran very poorly; hesitation, bogging, other various faults.
So my advice is get 'em fixed.
That said, the front sensors ( i think) provide the feedback to the mixture control unit. The rear sensors are there to generate a differential reading and thus be able to measure the efficiency with which the cats are working.
note that a rich mixture, caused bya relatively cheap o2 sensor, will eventually destroy a very expensive cat.
Grant
Grant
1. ALl 4 O2 sensors failed, simultaneously, with the same mode of under-reporting mixture (p=low)
--or--
2. Something is making it run rich and possibly placing the O2 sensors in an out-of-range condition so they all show a code (p=high)
Your call :-)
Grant
--or--
Your call :-)
Grant
