H&R Coilover installation, DIY?!
Search the tech section for suspension installs to get an idea at what you're facing...modern Audi suspensions are built very much the same, if not identical.
Rear on the A6 is different. Search for rear install info under my name ("2 Bennett suspension" may help with the search). I believe that Kris Hansen has also posted install info.
If you've done other suspension installs, you'll likely find this fairly easy (provided you have no rusted/frozen nuts/bolts)
Good luck
Mike
Good luck
Mike
osu s2k
04-10-2005 07:41 AM
A6@17
13
04-09-2005 05:47 AM
2.7Twin
01-16-2004 06:29 PM
