Had a momentary flashing CEL... any thoughts
I've had the constant flashing CEL before, back during the summer, and had to have plugs and coils replaced to deal with it. Tonight, I was just pulling into school and heading for the parking lot when the CEL started flashing for about 5 seconds before stopping and going dark. Any thoughts on what this could mean? Is there a serious problem going on that I should get looked at? Or does a flashing CEL happen if there's just some sort of momentary screwup?
Expect your CEL to come on and stay on.
Flashing CEL generally means stop the engine asap (if it stays flashing) because there are bad things happening, misfires, leads to cat overheat/failure, etc. However, just because the flashing CEL went out doesn't mean a code wasn't set...there's probably one in there. Get the code read and go from there.
The evap purge valve is pos too... It seems to be a 60K mile replacement item... The original one welt out at 13K miles, and was replaced under warranty, it started going out again at 70K.
The only way to know it to read any codes. Make friends with someone that has a VAG-COM...
I'm in the car ight now with VAG-COM open - The only fault codes I got were 01274 - Air Flow Flap Positioning Motor, and 01592. Doesn't seem to be a misfire codes. BTW, this momentary flashing happened again just before I got home and ran the scan, and it went away again after a few seconds.
Well, I used the "Auto Scan" which I think scans all the units. It's the same scan that has given me all past codes (including the last time I had the flashing CEL due to an engine misfire)
Love It or List It
Q5/SQ5 MKI (8R) Discussion
17
02-03-2022 07:30 PM
LIRS6
02-16-2007 08:19 AM
Boostd4
04-10-2002 08:38 AM
