Hazard Signal (Flasher) Switch Removal
OK before I get out the 2lb sledge, is there any secret to removing the hazard switch in the dash? Because I ain't gettin' it!
I've read the FAQs, reviewed the available pics but after removing the plastic trim piece, try as I might, I cannot remove the switch. Of course I was able to remove the red triangle part thereby exposing the innards of the switch.
I know from pictures that there is a sort of spring on the left side of the housing that I'm guessing keeps the part in its place in the dash, but needle nose pliers and other shiv-like devices notwithstanding all it will do is wiggle!
What am I doing wrong? Where else should I look? Thanks in advance...
https://www.audiworld.com/forums/sho...ht=turn+signal
https://www.audiworld.com/tech/elec160.shtml
It was very difficult to do on my car too, and I used needle-nose pliars. You'll probably end up damaging the plastic a little (where the pliars grip), but it will be invisible once assembled back.
A real pain.
A real pain.
Check to be sure that there's no dried out spilled coke or whatever sticking things together - the PO of my A6 spilled so much pop from the cup holder that I'm still digging it out of crevices; it actually stuck the Symphony radio head in so I could barely get it out...
Jim
Jim
Thanks for sharing Jim. I'm no Boston Driver but I thought even I could do something what appeared to be so simple a task. Now I know otherwise.
Jon
Jon
JMBlur
04-01-2008 02:05 PM
Does anyone have a photo that shows how to remove/install the cup holder/Nav_c toggle switch next to
Felk_2.7T
08-19-2005 08:58 PM
art2.7t
11-10-2004 03:07 PM
Jack Wang
09-22-2002 11:27 AM
