Headlight Adjustment in VCDS
...and yes, I did search first. I read through the procedure here: http://wiki.ross-tech.com/wiki/index..._Light)#Coding
and I keep getting ERROR in both Group 1 and Group 2. My HUD for the headlight adjusment symbol is illuminated all the time and there is a fault for headlights needing adjusted. I checked and the coding is correct for my car. Just don't know what to try next.
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00050
Shop #: WSC 02334
VCID: 040D92C914003E9
1 Fault Found:
01539 - Headlights Not Adjusted
35-00 - -
Coding: 00050
Shop #: WSC 02334
1 Fault Found:
35-00 - -
Yes it's attached, and when I look at the readings it says about 4.5volts for front sensors and 1.9v for rear...but no matter what I do to try and adjust them according to ross tech directions, it says "ERROR" in both fields. The warning light in the dash is really annoying.
cobrar97
Q5/SQ5 MKI (8R) Discussion
09-25-2015 01:17 PM
