Headlight Washer Leak
#11
But sounds like either the cylinder or the hose to it is compromised. Another reason I 'deleted' mine...
<img src="http://pictureposter.audiworld.com/13357/02080022.jpg">
#12
Thanks. I'm actually in MO (just bought the car out of texas, no salt, etc.). I called the dealership and they think it's just the hose from the cylinder on the driver side to the unit on the passenger side. We'll fin out monday.
Thanks everyone for the help.
#13
rigid plastic pipe, not hose, with a mushy O-ring seal to the cylinder nipple. That O-ring is the failure point. Replace with Si caulk.
#14
its a little plastic clip (white) on the hose that allows quick disconnect of the hose when removing the front bumper for putting into service position. This may be loose or broken ...its a cheap quick connect and could become easily damaged.
#16
Think about it for a few minutes before shooting down any suggestion ... at least that's what I have found out in past experience when I ended up with my foot in my mouth!
#17
i have found in the case of these cars to not assume anything .....especailly with the flimsy *** connections in either tubing or wiring in these cars ..... very cheap stuff .... guess they had to cut corners somewhere.
gimp2.7
10-17-2004 08:24 AM
Dommi3
04-24-2002 07:27 PM
mjbrox
12-10-2001 12:52 PM
