When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Dont take out the metal brackets for the visor lights or the plastic light/sunroof
Originally Posted by A699avant
So I have scoured the forums I have Googled in every way imaginable to see what others have done with the headliner metal trim that the visor lights sit in that are hard pressed into the headliner and to go around the new headliner. Also on the rear light. Then another issue I came across was trying to cleanly disassemble the frame for the map lights. It is plastic soldered together and a pain to remove but had old glue underneath. I managed to get it apart in one piece short of one small crack I plan to fix with jb weld plastic weld. The metal I will attempt to squeeze back on but I really dont see how without getting tool marks allover my new headliner. Any advice is appreciated also I'm a mechanic and this is my first real attempt at interior repair. I already epoxyed all my plastic clip retainers on the b c and d piller biscuits even the one I exploded on the drivers front. What about getting like 9 one or two inch c clamps and squishing down the top frame to the bottom frame maybe even heating it as I go to make it fit then when everything is tight epoxy it back together. 99 a6 avant
so I took mine out because i didnt want to have any left over orange glue or headliner material. I dont advise it they misshape and are a complete pain to reinstall. Just cover them up and give a little more of a squeeze shove to get them back in place
