Hello All
Engine Oil - Change the oil.
Engine Oil Filter - Replace the oil filter.
Cooling System - Check the coolant level. Add coolant if necessary.
Exhaust System - Check for damage and leaks.
Engine, On-board Diagnostic - Check diagnostic trouble code memory. Purge if necessary.
Doors - Lubricate door hinge mechanism.
Battery - Check electrolyte level. Add if necessary.
Windshield Wiper and Washer - Check fluid level. Add fluid if necessary.
Automatic Shift Lock (ASL) - Check operation, including park/neutral position switch (where applicable).
Manual Transmission - Check gearshift mechanism and clutch for proper interlock operation.
Tires and Spare Wheel - Check for wear and damage. Check the pressure.
Service Reminder Indicator Display - Reset the display.
Brake System - Check for damage and leaks. Check thickness of pads and brake fluid level.
Drive Shafts - Check the boots.
Road Test - Check braking, kick-down, steering, electrical, heating and ventilation systems, air conditioning, and power accessories.
Lights - Check the lights.
mrvirgilg
01-27-2005 12:45 PM
2000SForce
12-13-2004 02:05 PM
MYTTS
09-04-2004 08:54 AM
