Help with codes for 01 A6 2.7
Hello all,
I have pulled the codes on my wife's A6 after a CEL came on. I unfortunately don't have the Bentley for her car, only for my A8. Can anyone give me insight on these codes? Thanks for your help.
Address 01: Engine
Controller: 4B0 907 551 T
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 02325
WAUED64B01N118348 AUZ7Z0Y1754167
3 Faults Found:
16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
P0421 - 35-00 - -
16815 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
P0431 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 01: Engine
Coding: 06752
Shop #: WSC 02325
3 Faults Found:
P0421 - 35-00 - -
I don't have my Bentley on this computer, but I imagine that the other two are likely dead O2 sensors or possible dead cats. I can check my bentley this evening, unless someone beats me to it. ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Also, try searching the B5 S4 forum for those codes...I'm sure they've been addressed on more than one occasion. HTH!
Audiholic
Cat efficiency codes are telling you both cats are bad. They are under warranty if you have less than 80K on the car. Be prepared though to purchase up to four O2 sensors, as your dealer may tell you they can't get the old ones off. Chances are they will come loose, but be ready.
I'm chasing a similar problemfor a friend and was refered to a TSB Issued August 22 2006.. I think it is number 2012357.. applies to ECMs with the following part number 4B0 907 551 T - Eng code APB Trans Code Automatic (EYK, EMP, FAQ).. says that if your software level is 4000 or lower.. your ECM requires a software update (that changes the diagnisis threshold..) specifically refers to P0421 & P0431... Says (in all caps) DO NOT REPLACE CATALYTIC CONVERTER(S)!!
Pete K (vegasguy)
VAG-COM Discussion
12-13-2007 02:10 PM
