HELP HELP, A new problem has occured
AudiWorld Uber User
I am in Park, parked. The brake lights do not come on when I hit the brakes and I cannot shift out of park, is this some sort of fail safe device? Is it a fuse problem? I don't know what to do aside of call a flat bed and have it taken to the dealer? What can I do? I cant get the damn thing outa park and I have no brake lights anywhere, not the dash right or left. When I lock it though they light up for a second or is that a seperate bulb. Please advise, all of you?
brake sensitivity has been adjusted somehow. I cannot remember if there is a relay or not controlling the shift lock switch. There is a solenoid and that could be gone IIRC. I know this does not help you get your car going but check on the relay portion.
Also, someone has a pretty damn good diagram of the brake sensitivity adjustment and also the shift lock mechanism. I cannot remember how to defeat it however.
Disconnect the battery cable for 5 minutes, then reattach and try again.
These German cars often have electronic gremlins and disconnecting the battery is sorta like doing a hard-boot on your computer.
Good Luck!
Good Luck!
often I forget to add the damn emoticons or preview before posting. So I either come off as dry, insulting, boring, long-winded, or shallow (or a combination of AOTA).
I just thought it was a good idea and better to try that before digging into the relay panel etc. . . Also I remember someone posting about a modification and they had a pretty damn good diagram. In the post they mentioned a connection betweent he ECU and the brake switch.
\____/ Its all good! (how is that?)
Bri
Bri
brakes, ignition, steering lock, etc.
If you are getting no brake lights, then there is a problem with that part. Dig around near the brake pedal and see if you accidently kicked a wire off the brakelight sensor
to reinforce your thoughts and ideas. No matter how ridiculously stupid, off topic, or technically inaccurate. Hell I was surprised you contributed a minutely worthwhile piece of information to the forum. Don't make me pull a McLaren on you!!
Is this better. You need the tough love to feel good. :-)
