Help! High speed vibration. Rims are perfectly balanced. Control arms are solid.
What are the other causes of high speed vibration? The mechanics suspected something wrong with the driveshaft.
Vibrations only come at around 50mph and 70mph.
Try a roadforce balance, but even that will not cure a bent rim.
Plus, search for vibration issues. This topic has been discussed ad infinitum nauseum.
If the wheels are true, the tires are in good shape, and the suspension is solid, then I would absolutely look at the driveshaft.
Of course, as a last check, you could swap all 4 wheels and tires with someone else's known good set and see if the vibration goes away.
As opposed to just spin balancing by circumfrencial force, the roadforce machine actually turns them against a roller (moving road so to speak) which captures any uneven forces relative to the road surface.
What kind of tires did you get ? If you got cheap Vietnamese tires like Wanli or Nankangs.....then thats the cause.
I learned the hard way when I got some off of eBay.You get what you pay for indeed.
Yes, it could be a worn majro component, but 98% likely it isn't.
Most shops either miss OOR wheels and tires or dont think it is "significant" . On our cars, it is.
Grant
Grant
