Help identify this vacuum part 2.7T
Can anyone tell me what part this is in the picture?
It's underneath the PCV breather hookup to the y-pipe on the driver's side of the intake. It has about 4 hoses hooked up to it.
I had a MIL/CEL with codes P0171 and P0174 (lean fuel mix) and found this item to be cracked.
Part number would also be great if you know it...
2003 A6 2.7T
2003 A6 2.7T
Looks like a suction jet pump or a check valve, hard to tell from the picture. If you need check valves, I've got a bunch, provided they're compatible with yours. Suction jet pump is $30-60 depending on where you buy it.
Luckily (for you, not for me), I just broke this part on my mom's car when I had to pull the fuel rail. It is a vacuum check valve and will cost about $30.
Part # 078 611 933B
It is difficult to remove from the hard plastic tubing without a heat gun...many say to just cut the tubing and reconnect with vacuum hose.
Part # 078 611 933B
slowguy
09-09-2013 04:24 AM
rocketman4321
10-22-2008 12:35 PM
Kingttr
08-14-2006 05:38 AM
