Help Looking for advice Please read this!!!!!!!!!!!!!!!!!
Well I am thinking about getting a 2001 A6 Quarto and I need some help deciding. This car looks as new as the day it was made, however there is 53K on it so it has no warranty (crazy they only offer 4 year). I can get this car for a real good deal...... But do you guys think it would be wise with no factory warranty? I can get one from my bank I guess but will that be as good?
Second I am also thinking of getting a 2001 0r 2002 Volvo s60 with the 2.4T motor, looks nice and has 37K on it with 5 months of bumper to bumper and 3+ years of engine and drive train. And I can get as good of a deal for these as well.
Please offer any advice and or things I need to look at on the Audi to help me out here, I would like the best car I can get and I like both these cars a lot.
Thanks guys
Myrddin
Thanks guys
Myrddin
I bought one with 75K and had the car checked out and did carfax report..
My mechanic said the car is in near perfect cond. Carfax report came back great!!! Now just doing some scheduled repairs just to be safe. Timing belt all rollers and tensioners, water pump, thermostat, serptine belt. also have the tranny flushed and refilled with redline synthetic. Getting car back on Monday, One more thing their also doing the 0032 tranny recode and window and lock recodes!!!!
Bottom line get the car!!!!!!!!
Hmmm, wise? I would say buying cars is generally not wise...
If you are prepared to spend about $1500 a year (unless you like to do brakes, tie rods ends, timing belt, etc.) on maintenance and not cry about it or feel cheated because your expectations are in line with Hondas or Toyotas of the last 20 years, then GO FOR IT! Also, if you cannot self-insure (again, preparation!) for something awful (not normal maintenance or wear items) like a timing belt failure or Tiptronic tranny failure, you might want to avoid owning an A6 without an extended warranty.
You didn't say if you are looking at an Avant or sedan, or 28.8, 2.7T, or 4.2. They are each quite different; try them before you decide. You don't see many Volvos recommended on AudiWorld. :-)
Go to Audi dealer and buy CPO car for a total of 6 yrs/100K warranty coverage.
Sounds like the Volvo is at a Volvo dealer. Name one highline car maker like Mercedes or BMW that offers longer than 4yr/50K bumper to bumper warranty on new cars? I think even Volvo only goes that long on the original warranty. If you bought an S60 with 53K, you' be in the same boat.
The S60 is smaller than the A6, and slots between the A6 and A4 - a bit like the VW Passat - which in higher trim forms, would probably be a closer match.
See Stoney's FAQ in the link at the bottom of my sig for all the basics of A6 knowledge.
_________________________
Audi CPO warranty:
Compare CPO Programs
Automaker
Age in years /
Mileage Limit 5/70,000 5/80,000
Certification Benefits 300+-point inspection and certification, 24-hour roadside assistance, trip-interruption services, trip-planning services, Carfax vehicle history report, 24-hour customer service support and complimentary service loaner (services vary by dealer)
Up to 6 years/100,000 miles from the original in-service date plus balance of New Vehicle Corrosion Perforation Limited Warranty (12 years), plus the balance of no-charge scheduled maintenance for the remainder of the New Vehicle Limited Warranty ($50 deductible)
Volvo CPO warranty:
130-point inspection and reconditioning, 24-hour roadside assistance, trip-interruption services, trip-planning services and rental car
6 years/100,000 miles; $50 deductible
_______________________________
Here is alldata info on both:
"Bulletins for 2002 Volvo S60 2.4T L5-2435cc 2.4L Turbo VIN 58 B5244T3 LT
Safety Recalls
TSB Number Issue Date TSB Title
1. 08111 JAN 03 Recall - Trailer Hitch Defect
Service Bulletins
1. 2210040 APR 03 Engine - In-Car Piston Replacement
2. 2210049 APR 03 Engine - Updated Rear Crankshaft Seal Replacement
3. 772005 JAN 03 Suspension - Front Spring/Strut Replacement
4. 3360022 OCT 02 Wipers/Washers - Wipers Shudder/Noisy
5. 3390034 AUG 02 Interior/Audio System - Dash Speaker Grille Removal
6. 8870023 APR 02 A/C - Recirculation Door Air Leakage
7. 6650003 MAR 02 Dirt Deflectors (Rear Wheel) - Installation
8. 6650001 MAR 02 Shock Absorber Guard - Installation
9. 4410009 FEB 02 Clutch Pedal - Vibration
10. 3390033 FEB 02 Electrical Systems - Additional Wiring Diagrams
11. 4430034 FEB 02 M/T Shift Lever - Squeaking/Creaking Noise
12. 0076 DEC 01 Vehicle - Warranty Coverage Overview
13. 8870019 DEC 01 A/C - Air Intake Whistling Noise
14. 00205 OCT 01 Interior Safety Products - Reuse/Disposal
15. 00202 JUL 01 Policy - Service Upgrade Campaigns
16. 2250023 JUL 01 Electronic Throttle Module - Uneven Idle "
"Bulletins for 2002 Audi A6 2.7T Sedan Quattro V6-2674cc 2.7L DOHC (APB)
Service Bulletins
1. 940301 MAY 03 Instruments - Cluster/Illumination Configurations
2. 010307 MAY 03 Fuel System - DTC P1127/P1129/P1557 Stored in Memory
3. 270201 NOV 02 Battery - Correct Din Specification Necessity
4. 800201 JUN 02 A/C - Fresh Air Control Lever Light Inoperative
5. 910207 JUN 02 Audio System - Radio Inoperative/Display Dim
6. 910204 APR 02 Radio - Won't Turn ON/Low Illumination Intensity
7. 910203 APR 02 Telematics System (R) - Emergency Battery Shutoff
8. 170201 APR 02 Oil Cooler Hoses - Coolant Leak
9. 940201 MAR 02 Headlight - Moisture Accumulation
10. 010202 MAR 02 Immobilizer System - Obtaining 7 Digit PIN Numbers
11. 010201 FEB 02 Diagnostic Tester - 7 Digit Immobilizer PIN Update
12. 690201 FEB 02 Deployed Air Bag - Repair Warning
13. 910201 FEB 02 Navigation System - CD Release Versions/Usage
14. 010102 OCT 01 Engine - Hesitation/Lack of Power On Take Off
15. 910107 OCT 01 Radio - Deactivating Transport Mode at PDI
16. 440101 SEP 01 Alloy Wheels - Cleaning
17. 000107 SEP 01 Perfect Delivery Inspection (PDI)
18. 000105 SEP 01 Paint/Interior - New Vehicle Detailing
19. 000103 SEP 01 Paint - Rapgard(R) Inspection/Removal/Disposal
20. 500102 SEP 01 Paint - Swirl Mark/Fine Scratch Reduction "
Audi CPO warranty:
Automaker
Age in years /
Volvo CPO warranty:
Safety Recalls
Service Bulletins
Service Bulletins
I would be very careful with the fluid for the transmission.....
Use OEM transmission oil only for the automatic to prevent major failures. Redline oil is used in the manuals. ZF tip transmissions are very particular about oil used. Do a search and you will find a lot of good info, make sure your mechanic uses the correct oil
Re: from the Tech section...
The Audi is a 2.8. Can I get that PO warranty even with it having over 50K? The 2001 Volvo has a 2.4t and the 2004 just has the 2.4. I understand this is an Audi forum but I thought that someone could still give me some good advice because to be quite honest I know nothing about one or the other. I am ok with getting an aftermarket policy or Audi extended (if possible). I just want the better of the 2 cars that's all. I'm just looking for advice. I have the car fax on the Audi and the 2001 2.4t Volvo, both seem to be good cars one thing I see is the Audi is a bit bigger and the Volvo have about 16K less on the OD. Any advice these would be great. And if I did choose the Audi (if it's the best choice) Can someone tell me what to look into for warranty. I called the dealer and he said if the car had over 50K I was out of luck (didn't even offer an alternative).
Thank you all for your input.
AudiWorld Expert
The CPO checklist asks if car has less than 5 yrs/70k miles...
so I think that the car would qualify for CPO based on the miles, but not every used Audi at an Audi dealership goes through the CPO process. The certification does cost money, including the labor to repair the car, replace parts, etc.
Regardless of make/model you decide on, find one with certified pre-owned warranty. Just make sure you understand the differences between the programs. Many things not covered. Audi has a pretty good program for CPO. Not sure about Vovlo's. Here is a link to the 300 point checklist (just click on the link to download the cetification PDF):<ul><li><a href="http://www.audiusa.com/certified_certification/0,5779,110,00.html">http://www.audiusa.com/certified_certification/0,5779,110,00.html</a</li></ul>
