Help!! My 2001 C5 Avant is too slammed. In the name of cheap suspension mods, I took a set of
Intrax springs that came out of my former 2002 2.7t and had them installed in my Avant when I had the front control arms replaced. Shocks are the same for sedan & Avant, but not so for springs. The front dropped about 1", but the back dropped over 2" - presumably because the Avant weighs about 300 lbs. more than the sedan. The ride at slow speeds is fine, but hitting dips or bumps at expressway speeds produces the pogo stick effect. (Shocks are stock.)
For the same price I could swap out the springs for a set of Eibachs made for the Avant, or install Bilsteins or Konis in the back. I am leaning towards changing the springs, but does anyone think better damping control on the back would be the better option? Thanks.
Better ride and performance + complete control over ride height.
Several years ago I was in the same position you are today. I tried multiple springs and shocks before doing what I should have done in the first place - install coilovers
Good luck
Good luck
Shocks and springs are not good nor bad. They are either matched to deal with fundamental resonances, or they are not.
Similarly, springs require knowledge of travel, inetrference, and weight.
Throw int he towel - the best cheap suspension is the one that came with it. After that, be prepared to spend $1000 or more plus appropriate labor ( yours or money).
Grant
Grant
Change the spring rate or the wheel weight and you must change the shock's damping to keep it critical.
b5t
03-21-2005 04:02 AM
llonman
12-03-2004 10:37 AM
angryswede
10-28-2002 10:18 PM
