Hesitation and stumbling between 1400 and 1800 RPM
I have a very weird problem with my 02 3.0.
First of all I get hesitation when taking off. Seems to stumble along until I get into higher speeds and RPMS. That doesn't bother me so much as it only happens if I try to take off really fast. If I steadily increase the speed it's fine.
Here's the really weird part... If I'm going about 40-50 MPH and the RPM's are between 1400-1800 I get a slight stumble that feels like a misfire every 5-8 seconds. At the time it's in 6th gear. If I shift down into 5th gear and put the RPM's over 2000 then the problem goes away.
The CEL is not on.
Anyone else ever have this problem? Anything I should check on?
The CEL is not on.
VAG it and check for misfire...you might not have sufficient # of misfires to trigger CEL.
Could be/most likely is vacuum leak.
Wonder if I should take it back or call them and ask about it. How important is that check valve?
This is the check valve that was part of the vacuum lines.
<a href="http://www.autopartswarehouse.com/details/QQAudiQQA6_QuattroQQKayserQQVacuum_Check_ValveQQ19 952004QQW0133-1638665.html?apwcid=P1135867996W43b3f85c7ab9e&apwi dPYrH32g">Vacuum Check Valve</a>
Kojotous
02-09-2011 08:06 AM
problem of the week, high idle (1200 rpm) very rough also very rough in 1st and 2nd gear above 3000.
Audi Frank
04-19-2004 11:52 AM
Cord
04-12-2004 10:21 AM
RogDog
09-30-2002 09:19 AM
