How do I remove these clamps?
Working on aux pump replacement. Never encountered these oem clamps before and at a loss as to how to properly remove them.
Any tips?
Any tips?
you have to bend the retaining clip, honestly just cut them and replace with hose clamps (screw type). these types of clips are usually one and done unless your good and getting them apart. hose clamps are so much better in my eyes
screwdriver, cutters, dremel, pliers, lots of force, cursing, anything that you think you can use to spread it apart.
i normally use a pair of cutters to grip them good and just twist and pull until they come off.
dont get me wrong, there is a way to bend the retaining clip back to release it, and if your carful you can crimp it back together, but it realy is a pain in the ***, either have spares to throw on, or replace with hose clamps and enver worry again
And yeah, I have plenty of new screw type clamps to use when I put it all back together.
Those clamps are "produced" by automated machine so there is no question on the quality of the crimp. They are faster, more accurate and can produce a data point in the records, showing the crimp was made and the parameters of that crimp.
They are designed to be single-use. High end EU OEM's have been using them for decades and I believe EVERYBODY there uses them now.
I don't think the dealer service bays even have the machine. At least they didn't, 'back-in-the-day', when I had a warranty and would actually let them touch my car. If they needed to remove a factory hose clamp, a stainless gear clamp would take it's place.
Personally, I would look with suspicion at any re-used unit !
heinzboy57
13
09-09-2008 02:45 PM
pimpyellowtt
14
06-18-2004 10:04 PM
S4zero8
11
03-23-2004 09:47 AM
