How long can I drive with a bad Throw out bearing?
I feel a slight vibration if I depress the clutch pedal. I only feel it for the first 1/2 inch off the floorboard. If the pedal is all the way down, I dont feel it, only when i start to release the pedal. Thanks
defective). If it is the bearing, it could take some time before it totally seizes or fails. I would "watch" it carefully for signs of deteriation beyond what you're experiencing now. When it feels really bad, then it is probably time to have the transaxle removed, inspect the clutch assembly, and replace if necessary.
end float on the crank.
It is rare to feel it on the V6's but I guess anything is possible.
Try feeling the clutch on a golf GT Tdi PD130, it is very obvious as it is on quite a few of the VAG in-line fours.
Usually a worn/faulty thrust/throw out bearing will be noisy before you feel anything.
In terms of replacing it, if it is the bearing and it is that bad you can feel a vibration from it, I would say it is urgent towards gettuing it done in the next couple of weeks. If it end-float, don't bother - it means sump off and new main bearing shells, possibly on just the centre bearing.
Is vibration in the clutch pedal only attributed to a bad throw out bearing? What can I do to fix...
greenaudi100
Performance and Tuning
01-04-2004 09:15 PM
Ken 4000
07-13-2001 09:45 AM
