how long should tie rod ends typically last?
...by carefully lifting the edge of the boot just enough to get the syringe tip in there.
Also, if you really wanna talk about nuts, I believe Kris Hansen has actually drilled and tapped the ball joints on the control arms and rod ends so he could add Zerk fittings! I'd be worried about tagging the ball with the drill bit and/or getting metal shavings in the joint, though.
egustaps
09-17-2008 07:25 PM
CvTech
09-17-2004 10:50 AM
