How to loosen prop shaft bolt or remove u-joint
#11
#12
Not too sure how this project is going to end up.....
but on the plus side we have a new word. I will submit it to the Webster's Dictionary people tomorrow. I love it "dissassembleable." Perfect for the topic at hand too! Not sure I could have even spelled it and I'm having trouble pronouncing it but that may be the beer talking..........
#14
Yeah, I really don't know how to go about this...even if a could find a new u-joint and press the other one out...assuming the new u-joint came with circlips, wouldn't the shaft have to have the grooves for the clips to sit in?
And does anyone know where I may be able to source a new u-joint?
Thanks!
Thanks!
#15
#16
Thanks!
Thanks!
I would suspect you press out the old bearings, do your thing with the new center bearing, then press in the new U-joint bearings and stake them afterward.
#17
Thanks!
Thanks!
Not cheap by any means. I opted for a rebuilt shaft from this outfit. http://www.wholesaleimportparts.com/driveshaft.php
#19
Worth a shot depending on your budget. I also found a one piece with u-joint at each end that eliminates the center support mess. I would have gone that way had I not already done the rebuilt. I'll see if I can find that for you as well.
Here it is. http://www.advancedautomotion.com/in...c31c683a732d73
B56
09-19-2008 06:21 AM
Shan H
01-13-2008 05:57 AM
