How much should it cost to get the timing belt and gasket changed?
I just bought an 01 A6 2.7T and I have never owned an Audi before and was wondering how much I should expect to pay for the timing belt and gaskets to be changed? Any advice would be great, thanks!
1,600 to 1,800* could be less if you find a good indy.
Just a bit of advise when I say full service, do it not just the belt and what ever gasket you are asking about because if the job is that far into the front of the engine the water pump, thermostat, idle and tensioner pulley, crank shaft seal, timing and accessory belt should be done at the same time.
*service rates vary in different states.
And I'm located in TN, if you know any good shops.
The only thing I know about your state is there is some damm good guitar music spots when I was there and the folks were cool, not sure on repair shops though.
Keep in mind that very few people, especially shops, will automatically replace those seals.
Your range sounds stupid expensive, but in line with what I have heard that people pay for this work.
Well I haven't checked it out yet but the car is leaking oil and I have done some research of what I need to look at. But yeah I was talking about a full service TB, so you think that it might be around 1,600 - 1,800 for all that work? The water pump, thermostat, idle and tensioner pulley, crank shaft seal (with might be the leak problem), timing and accessory belt (1600-1800)?
There's a place called Tiedts Automotive in Madison, TN. That's the only place i'll take my car besides the dealership. He's replaced a power stage unit and a timing belt, both were below 1200 and never kept the car longer than 3-4 days
APTuning, LLC
03-09-2011 11:22 AM
APTuning, LLC
03-02-2011 09:13 AM
AUDIMAN3
Audi 100 / A6 (C4 Platform)
13
01-31-2009 09:44 AM
