how often should I change my fuel filter?
changed on 80k and I did a simple blowing by mouth test that filter was clogged like hell.
so how often should I change the fuel filter? 20k 30k 40k?
or simply 100 tanks of oil? which would be 30k-40k?
Why did you change it at 80K? If the car was running and you just happened to change it and found it appeared to be clogged...sounds like 80K was a good time to change it.
googled and someone recommand 40k, that's about 100-130 full tank of gas. Well changing the filter more often couldn't hurt, just a cheap insurance. So incase I get a bad MPG again I will change my fuel filter.
I did a major maintainence on 80K.. car was running @80k but mpg was poor, after changing the fuel filter, I can tell the throttle felt much better.So I think 80k/10years is a little long?
Therefore, I would not replace the filter based on time in grade, if you will. Replace it when you need to.
Truth is - it depends on how dirty your fuel has been - on average - over time. Do you buy randomly from stations? Run your tank near empty regularly? Or fill up at known high volume stations?
Giant it depends.
Incidentally, why do you think a clogged filter would reduce fuel economy? I dont follow the logic...
Grant
Giant it depends.
Grant
Giant it depends.
Grant
Giant it depends.
Grant
Giant it depends.
Grant
Giant it depends.
Grant
