I had a nail in my tire and had it pluged, but if i go to the track will it be a problem? Kumho Esta
I doubt you will achieving much higher than 100 mph on the track...I would think, even with the high lateral loads on the track around corners, I doubt you'd have a blowout related to the tire repair...I've never had a problem with any of the 8 patches I had in my tires on the Audis...although they haven't been tracked...but they were over 130 mph with the plugs...
But, Kumhos are cheap...to be "safer" (maybe)...get a new set that you only use for track.
I am shouting because I know of no track that will allow you to run with plugged or patched tires and when yours blows while tracking I don't want you plowing into me! You have a $40-50K car don't take a chance by relying on a "fixed" $400 dollar tire. If you want to track, do it right.
If your not sure still, then make sure you let the instructor at the track know about your tire prior to arrival. It could be a liability issue.
loTTusmark2000
Chicago Discussion
08-06-2004 09:59 AM
jgriff
Wheels & Tires Discussion
08-27-2001 04:44 AM
JCJiffy
05-12-2001 09:48 PM
