Ignition Coil won't Stay Down
Anyone have his happen. I changed my plugs on my 2003 A6, put it all back together and it's like I have a new car. A day of driving passes and the car seems a little sluggish (no check engine light). Pop the hood and Coil on cylinder 6 is higher than all other coils (partially came out of cylinder). Replaced the coil and it happened again. All other coils stay down, why won't #6 stay down. Am I missing something?
This is what forces over the plug and keeps it in place. If its vibrating loose then this may be the problem.
If this new Coil does not solve the problem. I will look at the plug again. Could it be a bad engine mount = excessive vibration (there is more vibration than normal)= moving coil???
New coil is staying down after 2 days. Rubber must have been worn the other coils.
Thanks for your help.
kodiak_karlito
01-16-2009 07:22 AM
JBSMOOTH
04-14-2005 10:35 AM
