Ignition Switch
Suddenly my climate control, headlights,wipers stopped working.Car still turns on and runs fine. After searching through the forums, I have concluded that it is the ignition switch.
My car is 1998 A6Q. can someone point me to a write up on how to replace the ignition switch on my car?
Thank you very much,
AudiWorld Expert
...from PaulW's archives, and it actually is very similar to the process for the C5 A6 as well.
Here is a link to <a href="http://www.audipages.com/Tech_Articles/electrical_equipment/ignswitchreplace.html">PaulW's writeup.</a>
Here is a link to <a href="https://www.audiworld.com/tech/elec162.shtml">my writeup on how to remove the steering column parts in an A6</a>, which has all the steps you need excpet for the ignition switch itself. (Note: you do not have to remove the signal stalk)
Hope this helps!!
Hope this helps!!
<center><img src="http://pictureposter.audiworld.com/78449/ignition_switch_98-01.jpg"></center><p>like me this one. I have to do it twice, because of my great dealer sold me the wrong part.
Looking at the D2 writeup, it looks very similar to the older Audis; the switch replacement is easy/simple...but you need a special socket to pull the steering wheel (Be sure to line it up straight before pulling it, so you get it back on correctly).
AudiWorld Expert
...so I would be able to easily replace the steering wheel properly centered.
AudiWorld Expert
I suppose that someone could remove the screws one at a time with the car on, turning the wheel to get at each screw. I think once the lower column trim is off, the ignition switch is accessible.
There is an online activation, but it just doesn't go anywhere (let it sit overnight and throughout a day).
Calling the cust. service I get an answering machine, leave messages, but get no return calls.
They all fell off the earth. :/
