im about to run to autozone for some things... yay or nay on a puralator oil filter??
#11
If you check out the specs on the Castrol website. On the BobIsTheOilGuy.com forums, it has a cult-like following. I believe I've read some B5 S4 guys are using it. There are 2 versions...green or gold. Seems the green was the original and supposedly is better, but is no longer available. The gold is its replacement, and is supposed to be very good also. It's fine to use, but if you are CPO or have an aftermarket warranty, its not on the Audi approved oil list, so you'd be better off with the Mobil 1 0W40 or Syntec 5W40 just to be safe.<ul><li><a href="http://www.audiusa.com/common/images/Audi_Approved_Oil_Chart.pdf">Approved Oils</a></li></ul>
#12
but why the relative caveat about changing oil at only 3 or 4K?
#13
makes the Bosch oil filters sold in the US, as well as several other brands, but they do not make Purolators.
Also, look at the specs and you'll see that the Purolator application for the S4 and other 30V engines does not have as high of a bypass valve setting as the Mann/OEM filters. You'll get unfiltered oil at high rpms/high oil pressures...
AvantMnkyA4
10-12-2006 10:20 AM
A6turbo530
15
08-14-2006 04:48 PM
S4_Cinci (I S'edTFA)
30v V6 Discussion
11-02-2004 07:36 AM
Formulaonefan
05-13-2004 01:30 PM
