Inside a suction jet pump. Sometimes I think it's a sickness which afflicts Audi engineers.
Old 05-24-2004, 05:26 PM
Eric 2.7's Avatar
Default Inside a suction jet pump. Sometimes I think it's a sickness which afflicts Audi engineers.
<center><img src="http://pictureposter.audiworld.com/61325/suction_jet_pump_002.1.jpg"></center><p>
Here is a partial view of the inside of the problematic suction/jet pump. The straight connection on the left comes from the brake booster. The connection on the right goes to the manifold (vac source). The branch comes from the junction can for the breather system.
The two orange circles are rubber diaphram check valves. Vacuum pulls through two paths. One straight through and the other through the venturi side. The venturi side pulls vacuum from the branch trading velocity for vacuum level (? why ?). So here it is. WTF, mates.
Keep in mind that this animal only exists on certain models (Tips 2000, and I forget how far beyond).
Old 05-24-2004, 05:29 PM
Junior Member
2.7tDallas REFORMED's Avatar
Default so when it gums up - the brake booster calls for mor vac to operate
then hwat happens?
Old 05-24-2004, 05:41 PM
Eric 2.7's Avatar
Default I'm thinking the branch/venturi side becomes clogged eliminating that pull on the breather
system while the larger bore side stays operational and keeps pulling from the brake booster as required.
The two halves are isolated completely from each other, and there are plenty of small clearances on the branch side to get gummed up.
I'd still like to figure out if I can just eliminate this puppy and connect the can directly to the manifold.
Old 05-24-2004, 06:18 PM
saabSean's Avatar
We've got them on '99 2.8s
Old 05-24-2004, 08:12 PM
Junior Member
NJ4.2GUY's Avatar
Default I have a 2000 4.2
is that gonna go on mine too?
Old 05-24-2004, 08:50 PM
StoneMan's Avatar
Default Pic got P0wned!
Jeez, and you'd THINK it would be Audi related!
Old 05-25-2004, 03:15 AM
Eric 2.7's Avatar
Hey AWMODS, this is a part from an A6 - Audi Related.
Old 05-25-2004, 04:46 AM
AudiWorld Uber User
JimR's Avatar
FWIW - the parts and service guys at my local dealer call that a "suck pump".
Old 05-25-2004, 05:27 AM
Head Cat Herder
Kris Hansen's Avatar
Well, it *does* suck!! :-)
Old 05-25-2004, 05:37 AM
Eric 2.7's Avatar
I don't see it on ETKA for a 4.2 so i think you are in the clear.
Quick Reply: Inside a suction jet pump. Sometimes I think it's a sickness which afflicts Audi engineers.
