Issues with AWE DTS - damaged chassis threads
Just wanted to let you know about a problem I've had after installing the AWE DTS. It appears that, if you re-use the existing 110mm bolts, there is only part of the bolt thread inside the threads in the chassis (due to the 3/8" thickness of the DTS), which can result in them stripping.
My tech discovered this last week, and the solution was to find new 130mm bolts and re-tap the chassis threads.
So if you're planning to install one, check that 130mm bolts are included in the kit, and if not purchase some before you start.
I told AWE about this but their response was just to assure me that there can't be a problem as they've been making this kit for years.
