Just a quick ? about wheel alignment... is 4-wheel absolutely necessary on Quattro? read on...
#15
Maybe you went fast enough to get a relativistic effect?
But then all the wheels would be slightly younger than the rest of the car.
Its true! Airline pilots spend so much time going fast, they're a second younger than than the rest of us at retirement!
#17
By "camber equalization" you mean moving the SF R or L such that camber is equally....
bad on both sides? But that's not alignment, not correcting camber errors, just equalizing them, L to R. The Sport suspension, having F flange mounted wheel bearings, can be camber corrected/adjusted by shimming the bearing mounting flanges, BTDT in all DIY alignments.
Total Toe, F&R, should be centered on the chassis for the car to go down the road straight, not crabbing. I center toe on the B pillar to pan weldament spacing, an easy measurement in any DIY alignment procedure.
#19
"F" = typo. Delete. You apparently are not familiar with the '02 C5 Sport suspension!...
The flanged wheel bearing face bolts to the Al vertical member, thus is easily shimmed to adjust camber. 0.035"= 1 deg camber.
thewatcher101
09-25-2007 04:35 AM
massmole
04-26-2002 01:10 PM
James R.
05-13-2001 02:12 PM
