Last edit by: IB Advertising
- Audi A6 C5 How to Reprogram Key Fob<br>Step by step instructions for do-it-yourself repairs.
Key Fob Reprogram Issue - What am I doing wrong???
Hi,
O.k. - what am I doing wrong? I followed the key-fob reprogram directions in the FAQ to the letter. Got a very nice blink confirmation from the lights saying "yes, the remote was programmed correctly". But IT DOESN'T WORK. Two 3 button key fob remotes, (both off eBay). Both program just fine. (one as #1, one as #2). But after they're programmed... nothing. I tried "re-synchronizing" the system, where you push either the "lock" or "unlock" button on the key fob remote and then lock or unlock the door with the actual key within 10 seconds. This failed to produce a result. I must be missing something here... any ideas?? TIA.
-Brian Bowman
2000 A6 Avant quattro 2.8
Ming Blue / Melange
-Brian Bowman
Ming Blue / Melange
This is based on the tech section steps that I wrote, but with an added "wait" (step 4). MAKE SURE you do EVERY step (print it out and tick each one as you do it):
1.Take one key/remote (key B) and put it in the ignition and turn the ignition ON (to the "accessory-on" position - don't start the car).
2.Close and lock the driver's door with the other key/remote (key A) while the ignition remains on.
3.Take the key A remote and press the "UNLOCK" button ONCE only - alarm will 'beep'/lights flash, but door will remain locked.
4.Wait for a slow count of 10.
5.With key A, unlock and lock the door again (using the key not the remote).
6.Test the remote by pressing the "UNLOCK" button again - door should unlock.
7.Open the door and turn ignition off and back on again using the key A this time.
8.Continue the procedure for the second remote - close & lock the door with the key B (leaving the ignition on).
9.Take key B remote and press the "UNLOCK" button TWICE - alarm will 'beep'/flash each time button is pressed but door will remain locked.
10.Wait a count of 10 again.
11.With key B, unlock and lock the door again (using the key not the remote).
12.Test the remote by pressing the "UNLOCK" button again - door should unlock.
13.Remove both keys, close the door and perform a final retest by locking and unlocking the car with both remotes.
If this doesn't work, repeat WITHOUT steps 5 & 11. If that doesn't work, you're on your own :-[
I have read all the entries and tried many things. Both main keys the battery died and the key will not turn in the lock of the one I replaced. Please help!
When I bought my A6 the fob wasn't working either. I put new batteries in and still nothing. One day out of habit from my old jetta I hit the unlock button and it worked again...LOL
It seems your lock/tumbler assembly is seized. Either unseize it or get it replaced and reset to your key's mechanical cut.
I was following the instructions tried few times but not working, my car is 2011 A6 C6 , got the new key cut from the Audi dealer, does anyone knows can I programming the new key fob without computer help? thanks a lot!
Wrong forum for your car. This is for A6 C5 cars.
TTitan4
02-11-2008 07:21 PM
nemesisa6
02-03-2008 02:28 PM
derekcmoore
10-12-2006 06:34 AM
