left front turn signal not working...tried a lot so far...no luck.
so for a few months now my left front turn signal has not worked. it doesn't flash when i signal to turn, it doesn't flash when i arm/disarm the alarm. the left side marker and left rear work fine. i'm getting a fast flash on the dash, as if a bulb was out. so far, i've replaced the bulb (even though it looked fine), replace the flasher switch in the dash, cleaned the contacts on the bulb holder and socket, swapped the bulb holders left to right...nothing. left signal still won't light. today i tested the voltage on both sides thinking it MUST be a wiring issue, but both sides tested the same! and i have no problems with the right side signal. i'm stumped. completely stumped. if i had more cash right now, this is about the time i'd break down and take it to the dealer, but i really can't afford that right now. electrical issues are not my strong suit. grrrrrr... anyone have ANY ideas?? THANKS!
Does the left front light with the hazard/4-way flashers?
Do you have a good ground at the front...check with an ohmmeter.
Is there voltage to one of the contacts on the LF turn signal with the bulb out? Use a DVM with the ground to OTHER than the other contact.
like i said, electronics are NOT my strong suit, so if you could give me any more direction as to what to check and how to check it, i would sure appreciate it! i'd LOVE to get this figured out...thanks!!
I'm guessing the turnsignal/hazard warning module is bad at this point.
S4LUVR
01-17-2003 06:51 PM
Steve C C
12-30-2002 08:51 PM
sams
02-14-2002 12:27 PM
