Lemmiwinks post
Old 12-26-2005, 04:49 PM
a_o_smith's Avatar
Default Lemmiwinks post
for all those interested this is ripped off from vw vortex:
you can download lemmiwinks at:
http://badger-5.com/bin/Revo/Lemmiwinks.exe
Ch01 : Idle Speed Offset
Adjust idle RPM level
- Higher number: increase idle rpm
- Lower number: decrease idle rpm
Ch02 : Fuel Tweak (Accel Pump); Increasing Loads
-This channel adjusts a fuel enrichment under load
-Modulates Throttle Response
Ch03 : Fuel Tweak (Accel Pump); Decreasing Loads
-This channel adjusts a fuel enrichment term coming off the gas or decelerating.
Ch04 : Start Up Fuel Enrich
Amount of fuel on any start ups?
- Higher number: enrich the mix
- Lower number: lean out the mix
Ch05 : Warm Up fuel Enrich
Amount of fuel on start ups E.G. on the first start in the morning?
Ch06 : Lambda Regulation
Controls how fast ECU adapts:
- Higher number: faster adaptation
- Lower number: slower adaptation
Ch07 : Additive Offset To Speed Limiter
Controls speed limiter in increments ok 1km/hr
Ch08 : Secondary Fuel Tweak
Controls fueling at idle, ussually alters additive fuel trims
- Higher number enrich the mix
- Lower number lean out the mix
Ch09 : Ignition Timing Offset
Controls timing in steps of 0.75 degrees, all RPM range is altered
- Higher number advances timing
- Lower number retards timing
Ch10 : Primary Fuel Tweak
Controls fueling on run, ussually change multiplicative fuel trims
Ch11 : Unused
Unused
Ch12 : SEL Scaling (Turbo Cars Only)
Adjust boost
- Higher numbers increase boost pressure
- Lower numbers decrease boost pressure
Ch13 : OFF OFF
Unused
Ch14 : Idle Torque Additive Offset
Controls engine load at idle
- Higher numbers: spec load at idle is increased
- Lower numbers: spec load at idle is decreased
Aditional Information from Revotechnik:
Adaptation Channer Explanation
http://forums.vwvortex.com/zerothread?id=1191064
Revo Comparison of Adaptation Channels and Tuning
http://forums.vwvortex.com/zerothread?id=1191128
How to:
1. Place key in ignition, turn to on position.
2. Attach VagCom 'dongle'.
3. Bring up Lemmiwinks software
4. To store original ECU settings Click ON "Read". This reads your current settings.
5.Adjust settings at will.
6.Click on 'SET' to connect to the ECU and adapt settings.
7. When asked to cycle ECU, simply turn it off, then turn the ECU back on.
8. Enjoy (hopefully) new settings.
Hints
1. Take off your Instrument Cluster Fuse if you can't establish communication with the ECU. clear airbag DTCs.
Special thanks to Don R, MRP2001GTi and BMFJETTA for great information.
BSK auf Arbeit
06-22-2006 12:21 AM
Nappy
Audi allroad
03-13-2006 10:37 AM
BSK auf Arbeit
12-06-2005 02:57 PM
Woland
16
04-19-2005 10:45 AM
TonyStarkz
19
02-02-2005 11:58 AM
Quick Reply: Lemmiwinks post
