The less expensive 2004 4.2 A6 may be cheaper because...
I said here last week that Audi are going to price the 2003 4.2 at $46,900. I believe that they will delete the passenger seat memory and tip controls in the steering wheel. (at least as standard). I took a 4.2 for a test drive today and I realized another way Audi may be saving money in order to drop the price for 03. It has been reported that the Allroad is to get the 4.2 and that Audi had to modify the engine to make it fit it the standard A6 engine compartment, the 4.2 having a different front end than regular A6's.
If so then maybe the modified engine will be fitted to the A6 4.2 with the standard front end, thus saving Audi the expense of building a different front end for the low volume 4.2. As the S4 is also going to get the 4.2 maybe the modifed engine also gets used there as well????
This would allow Audi at least an excuse for dropping the price by nearly $3,000.
S4? They moved something to the rear of the 4.2 to put it in the new S4, I remember that much.
do you have to drop the tranny do change the belt? isn't there a P-car where the motor has to be pulled to do the timing belt or something..?
